Need Help With Battery Charging
  • Bigtank216
    • Sep 2012
    • 9
    Hello All My Names Jon.. i have question i am trying to put together and small Battery pack for power outages & to recharge
    my Laptop & Cellphone something portable & lightweight my thing is im planning on using a solar panel to recharge
    The Batteries .. so here what i was thinking Equipment wise,, Goal Zero Nomad 7 Foldable Solar Panel, Sunforce 60031 10 Amp Digital Charge Controller,,and (2) 12 Volt 7 Ah Sealed Lead Acid Rechargeable Battery - F1 Terminal,,
    I Need To Know If This Be Right Rig If Its Too Small Or Too Big .. Thank you
    Hey Sorry I didn’t Include Data / Specs .. hope this helps
    Nomad 7 Solar Panel
    Approx. Charge Time:
    Cell phone, MP3 player 1-3 hours
    Smart phone, GPS, USB camera 2-4 hours
    Solar Panel Rated Wattage: 7W
    Cell Type Monocrystalline
    Open-circuit voltage 6.5-7V
    Converting Efficiency 17-18%
    Cell Area 0.0394 m2
    Prevents overcharging 12V Batteries
    Maintains 12 V Batteries in a fully charged state
    Charging light indicates Battery Charging
    Green Light indicates Full Battery
    UPG 40800 - UB1270
    AGM Battery - Sealed Lead Acid –
    12 Volt - 7 Ah Capacity - F1 Terminal
    My laptop
    Gateway NE56R34u Laptop Computer
    Battery Life Up to 4 Hours, 30 Minutes
    Battery Capacity (mAH) 4400 mAh
    Battery 6-Cell Lithium-Ion
    Power Supply Wattage 65 W
  • Naptown
    • 6880
    Please include the manufacturers specifications or data sheets when you make inquiries. It makes it so much easier to look and respond without having to do a search for the different parts and what they are.
      That tiny solar panel (7w, 7 volt), will barely have enough power to charge A cell phone OR A bluetooth.
      It cannot charge a 12V battery, and it would take a week to harvest enough power to run a laptop for 10 minutes.
      Sorry, it''s back to the drawing board.
      or check my .sig for the link to my Solar Monolith - it might jar loose an idea or two that may
      help you.
      Solar Monolith. Simple instruction photos here
      You can place 2 batteries on the bottom, which act as ballast, and the shelf holds chargers and other goodies.
      I used 60W flexible amorphous panel, but using a poly or mono panel, you can get higher efficiencies, with the
      risk of breaking the glass.
      • Bigtank216
        • Sep 2012
        • 9
        Ok
        Ok Mike I Just Did Some Thinking & Listened To ur advise & Checked out ur setup thats very kool nice and neat but id Like to keep it moblie & Light Because where ilive we have alot power outages
        Just Want To have my Cellhpone& Laptop Handy So heres
        what i revised if u think this do the job i buy ASAP...
        Cleveland Ohio Sun Hours peak @ 4 to 5 Hours
        Escape 30 Solar Briefcase $239.99
        Sunforce 60022 30 Amp Solar Charge Controller $78.84
        DieHard Marine Deep Cycle/RV Battery, Group Size 24M ]
        Power Ratings:
        Amp Hours at 20 Hour Rate:80
        Cold Cranking Amps (CCA at 0 deg.F):500
        Reserve Capacity (RC):135 min.
        Useage Charges from the following:
        Escape 150 Power Pack 6-8 hours
        Extreme 350 Power Pack 12-24 hours
        INPUTS
        Rated Wattage: 30W
        Cell Type: Mono-crystalline
        Open-Circuit Voltage: 18-20V
        Converting Efficiency: 17-18%
        Output
        12V Charging Port (4.7mm)
        14-16V, 2.0A max (30W), not regulated
          I like the battery, just get a plastic Marine Battery Box to haul it around in. (about $15)
          I've heard of the brand of controller you mention.
          The briefcase PV is my worry. It might look sexy, but only 30 watts ! For that price,
          you can buy a full size 200W panel, and have - - 200 watts. For half that price, you
          could get a 100W panel, and be able to power everything. Wrap the edges with foam pipe insulation
          and you are nearly all set.
          The drawback with a 30w panel, it will take 4 hours of sun harvest (10 am - 2pm) to run your
          laptop for 1 hour.
          Many people under estimate their loads, and the sales brochures over state the capacity -
          Cell phone, MP3 player 1-3 hours , Smart phone, GPS, USB camera 2-4 hours and neglect to tell you that it only works at 8,000' elevation where the air is thin and the sun is strong. otherwise, it takes the 7w panel, 2 days in Florida to accomplish the recharge.
          • Bigtank216
            • Sep 2012
            • 9
            Well Mike You Been Big Help ..I See Id Brought Wrong Stuff And Blew Sumin Up lol
            Seeing What Ur Opinion was on the solar panel i found sumin like this its expensive
            but you know what crossed my mind maybe i just build ,my own solar panel im
            good at building stuff & also i found a pure sine wave inverter what you think now?
            Far az Battery box i sure didnt think about that and what i did was ordered and
            Luggage cart rated for 250 lbs load and im go just modify the wheels
            Instapark PowerBox Mars100 Fold-n-Go Portable 100-Watt Solar-powered 12V Battery Charger with Built-in Charge Controller & Cooling Fan $349.95
            Brand Instapark
            Item Weight 18 pounds
            Product Dimensions 26.2 x 2.8 x 26 inches
            Item model number SPB0104
            Manufacturer Part Number SPB0104
            Amperage 10
            Voltage 18 volts
            Wattage 100 watts
            Samlex PST 300W 24V Pure Sine Wave Inverter $139.79
            Design Features
            Switching mode design
            High efficiency
            Pure sine wave output voltage
            24 VDC input and 120 VAC output
            Overload protection
            High output current surge
            Low battery alarm / shut down
            Low idle power draw of less than 0.5 Amps
            Applications
            Service vehicles
            Mobile Offices
            Boats
            Recreation Vehicles, Camping
            Telecommunication
            Field work / Construction sites
            Solar power systems
            Emergency backup power
            Home electronics: TV, VCR, video games
            Computers, printers
            • Bigtank216
              • Sep 2012
              • 9
              Finally
              Hey Mike.Here What Im Going With
              Im Go Buy 1 Solar Panel For Now And Second One
              At later date.. then I'll hinge Both together
              and tie them together in paralle for 100watt
              that make the panels foldable like i want &
              easy to move and store & Portable..Hey If You
              Find Another Flaw Please Let Me Know
              and thank you for your help
              Solarworld 50W, 12V Module $122.97
              Duralast/Marine battery 12v 800cc $111.99
              Morningstar PS-15 ProStar 15 Charge Controller 15A 12/24V Price: $105.00
              Snap-Top Everstart Marine Battery Box $9.95
              Lynx/Marine battery terminal Price:$3.29 x 2
              Bell/12 Volt auxiliary power socket Price:$9.99
              Cooper Bussmann/ATC easy ID fuse •10 fuse pack $7.99
              Cooper Bussmann/ATC fuse holder $3.29
              total $517.55
                Look carefully there and see if you see the problem.
                I start Jury Duty on monday, and will not have much time to keep going over your shopping lists for you. Maybe someone else that has built a portable rig can offer suggestions too ?
                Mike
                • PNjunction
                  • Jul 2012
                  • 2179
                  Unfortunately, this is a good example of winging it, and throwing money away by guessing.
                  Even when using small-scale projects, unless you know your power consumption, one is nearly guaranteed to go straight to "deficit charge" jail. Do not collect 200 dollars. In fact, throw it out the window.
