I have a solar array connected to my controller that is connected to my battery bank and then to my load controller. I wanted to have a generator that I can connect to the system to charge the batteries incase weather would cause longer than normal dark day. My question is where do I connect it? Do I connect my external charger directly to the battery bank or do I unhook my solar array from the charge controller and replace it with the external charger? I would think either would work but something about hooking up to the batteries while the solar is charging the batteries and the load would cause damage....also, if my charger is 24v, which is my battery bank voltage, does the charge only charge to 24v or will it actually charge it at ~29v?
Connecting a generator to a battery bank
A 24V automotive charger will not fully charge a 24V deep cycle battery, automotive style chargers generally only get about 90% of an actual full charge into deep cycle batteries.
You may be better off using a AC powered 24V charger, to get 30V to fully recharge a 24V bank.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Hi Mike,
I'm using a AC Gen with a AC powered charger.
Where I'm at is wondering if I connect it directly to the battery bus bar and charge it or just replace the input terminal on the charge controller that currently have the PV array connected with the terminal of the charger? Or does it not matter?Comment
Hi Mike,
If it's a smart charger, you connect it directly to the batteries. Otherwise, you need to monitor it manually to figure out what is happening.
But why not tell us the model & brand, and include a link, so we can see what the charger is.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
