I have a ~ 1.5 yr old car battery, not to sure on the AH, but judging by its weight, i'd say upwards of 70ah capacity when new.
It was left connected in a non-running VW bug, and something in the cars wiring caused a short, or discharged the battery. Its my fault for neglecting it for this long, but its a relatively new battery. When i pulled it out of the car it was reading ~10.5v. Not good at all. I charged it with a standard car battery charger, at 5a overnight, then again at 2a, and it won't go above 12.4/12.6v after being charged. I popped the caps, and sure enough there was that sight that burns the eyes, white sulphate crystals on the lead plates. So its got some sulfation issues.
I ordered a morningstar solar pwm charger, and intend to use it with a 20w panel and a sepic to keep my solar panel voltage output stable, since under 13 its wasted, and over needs to be buck converted down to a charging voltage to keep a nice float charge on it and prevent desulphation. Witha 20w panel in northern california winter conditions i assume it will take a long time to desulphate this way. I'll prob end up hooking up a 15v 2-3A dc source to it so it desulphates a bit faster.
But my question is, i have a pwm dimmer for led lights, adjustable with a rf remote. Its rated at 8a 12v. I also have a ac/dc adjustable 12-15v 5a power supply. I want to try and see if i can use this to desulphate the battery a bit.
Can anyone advise me what voltage i should set the power supply at? I plan on running it at 13.5v 90% pwm to start, and see what they cell's voltage is after a few hours of charging, obviously keeping a close eye out for gassing/heating.
Is this a viable idea, or should i just wait for my morningstar and use that?
The only reason i ask, is these pwm dimmers are under $10 bucks, and all you need is an adjustable power supply for pwm charging if it works like i think it would.
Heres the link for the pwm dimmer, i got mine much cheaper, but its the first ebay listing i could find for the model i have-
