That would give you roughly 3 Kwh/day usage.
Yes. I did the calculator and that was very interesting. Since my demand is about half of Tuscon's where they needed 6000 wh, I need only 3000 or about. So I need about 8/100 or 9/100 watt panels. correct?
This will throw me into the 80 amp mppt charger too. correct? [/QUOTE]No that is not enough panel wattage. You cannot compare Tuscon with Mississippi. I have already shown you what it will take to generate 3 Kwh/day of usable power. In Winter you have 3.5 Sun Hours, not 5.6 Sun Hours like Tuscon. Look at the Seattle numbers I used. To generate the same amount in Seattle as in Tuscon required 7500 watts vs 1800 watts in Tuscon.
For you assuming you use a 25 amp or more MPPT Charge Controller you will need a 1200 watt panel array.
I would suggest you look at 24 volts for your setup. At 24 volts you need.
Panel Wattage = 1200 watts
24 Volt Battery = 625 Amp Hours
MPPT Charge Controller = 50 amps minimum. I would suggest you go with a 80 AMP CC as this will allow you to expand up to 2000 watt panels @ 24 volt battery, or 4000 watts @ 48 volts.
