1. I have (26) 2V Rolls Surrite batteries for my 48v Solark 12k system. 13 on a top shelf and 13 on a bottom shelf 2 rows of 6 running North/south on each shelf with a single 1  in the middle of the top and at the end of the bottom run. They are 1440 AH each if I connect them series then one in the middle in parallel then 1 at the end in parallel will that work? (having the positive from the 1st battery and the negative from the last battery (which also has a parallel connection on the post))?
2. what is my amp hours if that is correct? im sure i'll have to program that into the inverter at some point
3. I have the array set up and the batteries waiting for charge, but they are not charging yet, long story short were waiting on electrician to finish his work. Should i start charging them with a trickle charger, 20Car charger or something else?
4. how do you keep batteries warm? i have them in a wood shelf i built inside a building, but they are not warm. i placed heat trace around them and a small plate heater that cuts out at 80 but they are not getting upto 70s, staying in low 60s mostly. is there a heating product?
Frustrated here hoping to finally get this completed.
LMS
LMS
