For those with a 48v system. To disconnect the batteries once and a while to fully charge, what chargers are out there do you recommend?
Battery charger
With a 48v system, chargers are limited by the power your wall outlet can carry
I have a https://www.iotaengineering.com/dls5413.htm as a last ditch charger I can run from a 3kw generator. I usually use the 80A charger built into my inverter to charge batteries from my generator (at 30A)dc
Golf cart chargers can be use ( for a 48V golf cart) but they will require a 240VAC outletPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
