Hello kids!
Three years ago I purchased a 4kw 48v Solar package. 9 panels, Magna Inverter/Controller, 8 Rolls 440 ah FLA batteries. In all honesty, I knew little about batteries and little about using them properly. That lack of knowledge led to the loss of all 8 batteries after only 4 months of use. That being said, I've learned a bit more since, won't repeat the same error and let's leave it at that.
So, for three years, I've had these 9 solar panels that are doing absolutely nothing, I now have the opportunity to get some batteries and put the system back in operation, but.....
The caveat to that is I cannot afford the 440ah batteries I once had and I am faced with creating a lower power system, which is fine. I was originally going to go with 220aH AGM batteries, but again, the price is out of reach. So now I have my sights set on some 130aH batteries. I have one question.
If I get (8) 6v 130aH AGM batteries to make up my 48v system, can I add more batteries later to increase my power(aH)/storage capacity?
I was told once a while ago that if I wanted to add more batteries to my then 440ah system for more storage I would have to wire the batteries differently. Parallel vs. Series I believe I was told.
Thank you for your help and suggestions in advance.
Ted
Battery Advice and expansion
