Hello,
I am a little confused about how voltage works and the limitations of a system. A 40 amp controller and a 24V battery bank have a limit of 960 watts or so. With that in mind, If I have ten 100watt panels wired in pairs. Does that mean that I am only sending 500 watts at 24volts? So I could essentially put more panels if I wanted to as long as the total does not exceed the 960 watts? It is just mind numbing because the panels at 12 volts wire in serial add up to 1000 watts. I imagine that there is a limitation in amps also is it not? In which case I can neither exceed the voltage and or the amps whichever comes first?
The second question, If said pannels where wired in strings of three for a total of 4serial and 4parallel making the grand total of 12 100w panels in a 24volt system. What happens to the extra voltage above 24? I sit simply used by the house on sunny days or does it somehow helps expedite the charging rate of the batteries? My guess is that the excess power is wasted if not used, but I would like a clarification.
These questions are to help me understand the concepts, I am certain that a 48volt system would be preferred in this case.
Thank you
Thank you
