Connecting battery charger with generator.
  • Sub
    • 49
    i have a 48V battery bank, consisting of two strings connected in parallel. I use a generator to recharge the battery bank via a battery charger when the sun doesn't shine. Does it make a difference about where I connect the charger leads?
    What would work best, or is there no difference, if I connect the + & - leads to one string only, or should I connect, say, the + to one string and the - to the other?
    I'd connect right where all the other cables connect, which should be on the diagonal corners of the 2 banks:
    Combatting the problems commonly associated with conventional amp-hour based battery monitors, SmartGauge 12/24V is renowned as the World's most accurate battery monitor, as well as the easiest to install and use.
      Directly to the Battery Term Post.
