Battery Monitor Test Meter
Something like this TriMetric?
http://www.bogartengineering.com/products/trimetrics/Comment
The TriMetric TM-2030A is $150.
The TriMetric TM-20254-RV is $125
They have data logging.
If you don't exceed 30 amps charge / discharge then you may use use the device shown in your Ebay link.
NOTE the difference in wiring for "Remote Sense vs Internal Shunt".Last edited by NEOH; 08-14-2017, 09:16 AM.Comment
I have found that almost all of them in that <$30 price range are uni-directional and have no logging, like your eBay unit. I am looking at installing two on my friend's fifth wheel, he is getting them from Amazon. One for charge and one for discharge, using the same shunt and wires. He will be zeroing them out daily at sunset and using them as a daily SOC approximater. I see other people in the comments have got around this unidirectionality by installing a switch to reverse the sense wires during charging. I love the concept of the Tri-Metric, but hate the user interface to the point that I would never buy one.
I read we're supposed to limit external links so I will try this: search for "bayite DC 6.5-100V 0-100A LCD Display Digital Current Voltage Power Energy Meter Multimeter Ammeter Voltmeter with 100A Current Shunt" at Amazon...Comment
http://www.ebay.com/itm/LY6-12V-48V-...X%3AIT&_tr ksid=p2060353.m2749.l2649Comment
For now I'm getting a battery charge status in percentage is very cool,Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
25.48 volts fully chaged
24.76 Volts 70% charge
24.2 Volts 50% charge
I've been keeping them in the 70% charge range. All I need is a battery state of charge display to let me know what their state of charge is without using my meter every time. It may no be 100% accurate but at least I'll have an idea.
