It does. I guess the old fridge had more than one source of AC (fridge, icebox?), so my wattmeter didn't catch the problem. Thing must have been running 24/7. New fridge is larger and costs 1/3.
SunKing's suggestion to wrap water heater reservoir helped a lot too it seems.
Since I've been observing power usage and making changes, my kW used have decreased markedly. I started at 110kW and last week was down to 82kW. With a full week on new fridge, next week should be around 60~. Yeh for me!
Getting a handle on kW usage
Doesn't it feel good to find the problem?Leave a comment:
For anyone interested.
Change attributed to wrapping water heater and installing EE fridge. My solar project has already saved me $200~ a year.
BOOM!
Appears that fridge compressor is running 24/7, which I feared. This time slot is just 1/3rd a day (at coolest times, no less) so extrapolating over a full day suggests fridge alone is responsible for over 35% of my overall usage. I knew there was an issue because it would freeze up every few months (I did change thermistor and board already), now I know how bad it is.
New fridge ordered, and hey! 40% more capacity. Yeh for me!
Hot water heater insulated as well. Based on new fridge energy ratings, I think I just saved myself 5~ kWh per day.Leave a comment:
You might also want to check the thermostat and see what temperature the water heater is trying to maintain. They are usually set high but can be lowered to your comfort level and usage.How water heater @ 800kWh a night, which is ridiculous seeing that I'm sleeping with all windows open. I'm going to wrap it in insulation today while the temp is stable,and see if I can bring that down.
hwOFF.pngLeave a comment:
I just recognized that those 15 minute usage stats are 2 days old, so I'll have to wait through Saturday to find out about the water heater and fridge. I suspect it's the fridge because the site's on demand number, which is real time, didn't change much since yesterday if I recall correctly.Leave a comment:
That may eliminate the high energy user being the battery charging system, but unfortunately you still have a big vampire the sucks down your kWh about every hour or so during the night.Leave a comment:
The board's recommended hydrometer resulted in 100% (actually looked like it was above 100%). That was expected as they're only a couple of months old.Leave a comment:
Depends on the CC control system and the condition of the batteries. If they drop to a lower voltage the CC might go into high charge rate and then cycle off to float.Some load, yes. At this point that has to be either the fridge or the inverter ramping up charging for DC withdrawal on batteries. DC is consuming .5 kWh per day, do you think the charger stays in float mode to handle that or do you think it switches to absorb charge on occasion?
690ah/24v
I had a similar problem with my old Iota CC in my RV. My 2 x 6v coach batteries were going south and the CC kept trying to keep them above 12.5volts. It actually ended up boiling away most of the fluid in two cells so I replaced them along with a newer CC/inverter made by Power Max.Leave a comment:
690ah/24vLeave a comment:
It looks like you have a couple of spikes at 220wh. One at 12:45am and another at 5:30am with a few smaller ones in the 100 - 200 wh range. I still think you have some load that is cycling.No difference
Sunking, will a 120/3000/24 inverter/charger really use that amount of energy? It's the only thing left, but it's in float mode and DC usage at night is like zero.
edit: Actually, not the only thing left. Fridge gets shut down tonight.Leave a comment:
No difference
edit: Actually, not the only thing left. Fridge gets shut down tonight.Last edited by -TX-; 02-22-2017, 11:30 AM.Leave a comment:
The hard wired devices are the big users. The rest is peanuts.Leave a comment:
You're right on that. I know I can insulate it more, I'll wait on that until I find out much of a hog it is.Leave a comment:
