Sorry but there is no answer. There is no voltage high enough you can set your controller to fix what you do not have.
As you are learning solar is not capable of fully charging a battery. Especially if you live in a climate that has winter and undersized to start with. To EQ a battery requires up to 24 hours on a generator or commercial AC charger. As I said earlier Absorb is not a timed event. You simple do not have enough panel wattage to to replace what you use. Your Inverter with no load on it doing nothing, uses more power than your panels can generate in a day.
In other words like this. It cost you $50/day just to survive, but you only earn $25/day. You are either going to starve or freeze to death. Whichever comes first. The only thing you have working for you right now is cold weather. Your specific gravity is so low, it is just a matter of a short period of time before your batteries are past the point of no return. The cold weather slows down the process some what.
Sorry but turning up the voltage on your controller cannot fix your problem. It does not turn up the wattage you do not have. You are in deficit charging, and there is only one solution. If I were you, I would take the batteries home, put them on a charger to see if you can save them. After that you need to completely rethink things out and come up with a workable solution.
Good Luck
Good Luck
