Sunking, thanks for your newest sticky "Bulk Absorb Float Equalize: What Does It Mean".
This was very helpful as I was reviewing and trying to "absorb" all the stuff you, PNjunction, and others here were trying to help me in previous threads understand about how a lead acid battery gets charged, maximum smoke, etc.
So I think I get now how a on-grid charge controller interacts with the battery.
But I want to make sure I get how a solar charge controller interacts - esp in the Bulk stage through a PWM charge controller....
Sunking wrote:
"Bulk mode in a solar charge is not CC. It is Constant Power. What Power?. Who knows, depends on how strong the sun is...
...In Bulk at a few brief seconds around noon it was 10 amps for a second. What is it 30 minute after noon?. Something less than 10 amps. If it is hazy maybe 5 amps. All your controller can do is transfer the maximum available power at the time. It cannot do any more than that. So that makes it Constant Power, not CC..."
In another thread, PNjunction wrote:
"PWM" is really just a charging waveform that is different from a steady-state output such as from a typical linear power supply. The pulses (on/off) are so fast, you usually can't see it with average consumer voltmeter gear. In reality, the pulse varies from a very low state (such as in bulk when there is essentially NO pulse, and then it ramps up the pulsing very very rapidly for absorb."
So I just want to make sure I understand - HOW does a PWM versus MPPT solar charge controller get the varying power to the battery in the Bulk stage?
PWM: does a pwm charge controller simply and LITERALLY connect the panels DIRECTLY to the battery in the bulk stage and just lets whatever power pass through from the panels to the batteries until the absorb voltage is reached?
Or is it actually doing pwm "pulsing" but those pulses are maybe very long duration and each pulse has a different amperage/wattage or something?
MPPT: I'm guessing MPPT controllers definitely does not directly connect the panels to the battery in the bulk stage, since it has to do stuff like DC to DC conversion etc prior to sending the power to the battery, so does it use pwm to do that? Or does it simply send whatever the result is after it does its MPPT magic and it is "logically" as if it was connecting the panels directly to the batteries and no PWM is taking place in the bulk stage?
thanks alot again for the learning guys...
