charging a battery bank with both PWN and MPPT charge controllers
  • fopoku2k2
    • Jan 2015
    • 66
    Okay so my current setup has 2 sets of different panels. one set comprises of 2 250 watt panels and the other set comprises of 2 145 watt panels. the first set is connected to an MPPT charge controller and the second set is connected to a PWN charge controller. both charge controllers are connected to my battery bank separately.
    Is there anything wrong with this setup as in would there be a problem with the batteries being charged from different type and make of charge controllers??
    (I'll quote myself from another reply)
    Any panels that will be shaded, should be wired in parallel.
    If your panels are 18-20V nominal (max power) you can use PWM controllers to charge a 12V system. Most small panels are in this range.
    Larger panels could be 19V or 29V or 49V or 65V, depending what was being built that day. More than 19V panels (not looking at the Voc spec, just the V Max Power spec) you will benefit from using a MPPT controller.
    You can "generally" safely connect several charging sources to a single set of batteries, and all will be fine. Sometimes brand x just will not play well with brand y and you have to change something to make it work.
    • fopoku2k2
      • Jan 2015
      • 66
      what do you mean by change something to make it work??
      • Wy_White_Wolf
        • Oct 2011
        • 1179
        That would be for higher end charge controllers that the charge voltage parimeters can be adjusted.
        The biggest problem you may have would be the PWM controller never going in float mode (flashing when the battery is charged). That may happen because the MPPT in float mode may not let the voltage drop enough for the PWM to kick on. That really wouldn't hurt anything as the batteries would already be charged and you wouldn't need the power from both arrays.
        One could have a problem of the PWM kicking the MPPT out of bulk or absorbtion charging early. But I think for that to happen one would have to setup the PWM on a much larger array then the MPPT controller.
        WWW
        • fopoku2k2
          • Jan 2015
          • 66
          WWW
          oooh ok. great thanks
            • 15172
            Another way to explain the issue is that if you have two charge controllers on the same battery bank it is best they have very similar charging logic and voltage settings. If they are too different they will fight each other and can either fail to properly charge the batteries or over-charge them.
            Unfortunately there are many different panels sizes and charge controllers (at many different prices) to chose from which can be confusing. It is best if they are of similar wattage size and charging capabilities. Mixing items that are very different (and cheap) usually does not end up with happy results.
