Might want to recheck you math. If any of the batteries really had 9 or more Ohm;s would be boat anchors and completely useless. 3 amps x 9 ohms = 27 volts (not possible on a 12 volt battery). A dead bolted fault would only draw 1.3 amps @ 0 volts. For example battery A [13.0 - 12.7] / 3.25 amps = .0923 Ohms. you only missed it by a factor 100.
The good news is the batteries look A-OK for their size.
EDIT NOTE:
What this tells you is the max load the batteries can realistically handle in a working application. You want to limit voltage sag to no more than 2% of open circuit voltage. 2% of 12 volts = .24 volts. That tells you the max load is .24 volts / .09 Ohms = 2.67 amps. Or put another way 12 vols x 2.6 amps = 31 watts. The other thing it tells you is when your batteries have seen their better days and need replaced when at full charge you see the Ri has increased to 25%.
EDIT NOTE:
