Hi . I am brand new with solar. I have 90 watt panels. I have them charging 1 , 35 amp hour battery and another much larger marine battery connected together. Is there a disadvantage to this ? It seems like based off my calculations that I should be able to run things much longer than I am . Should I disconnect the smaller battery ? Will this make a differance ? They are both 12 volt .
Thank you
Thank you
