I have around 200 - 10 Watt / 5 Volt Output semi-flexible panels that I cannot use. They were ordered with a 5 Volt Output to try to power small electronics directly but obviously this was not stable enough to work for us. I am wondering the easiest way to either change the output voltage to 18v or a way to bank/use the 5v output. I am open to any creative ways to use these panels, I do not need to use them for the original purpose any more, but could if it makes sense/cents. Thanks.
Help! What do I do with all these 10W Panels?
ebay.
If your panels have wiring boxes on the backside, you often have the option to change jumpers. But small flexible panels likely don't have the terminal boxes. sorryPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
got pics?
(and if it is okay to ask) how much you want for the lot?
are some NIB, or have they all been used?
Thanks.[CENTER]SunLight @ Night[/CENTER]Comment
Thank you.Comment
