NEW AGM "Break-In"
Sears "Platinum" AGM are rebadged Odysseys. Unlike some other agm's, these are rated to sit around for up to 2 years, or 12.4v ocv whichever comes first. This aids shelf-life, although as always, fresher is better.
I picked up a few of these, and after about 5 cycles, they were back to rated capacity holding 13.15v ocv when charged according to Odyssey specs.
Most agm's that I've encountered really woke up after about 5 cycles, as the plate-formation process is actually finished by the consumer, rather than at the factory. Just a few cycles of normal use are what I consider a break-in period. I believe Odyssey actually specs about 15 cycles, but I couldn't tell after 5.Comment
That's what I was looking for... Thanks.Sears "Platinum" AGM are rebadged Odysseys. Unlike some other agm's, these are rated to sit around for up to 2 years, or 12.4v ocv whichever comes first. This aids shelf-life, although as always, fresher is better.
Most agm's that I've encountered really woke up after about 5 cycles, as the plate-formation process is actually finished by the consumer, rather than at the factory. Just a few cycles of normal use are what I consider a break-in period. I believe Odyssey actually specs about 15 cycles, but I couldn't tell after 5.[CENTER]SunLight @ Night[/CENTER]Comment
Based on all of that, I would say that the only place that a break-in period of cycling would really be important would be in a use such as a UPS where you need the battery to be able to perform up to its full potential the very first time it is used (which may be a year or two after installation). There would not be any normal cycling to complete the plate formation enhancement unless you do it deliberately as part of the commissioning.SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
So, in the case of a dusk-to-dawn light discharging the battery 20%,Based on all of that, I would say that the only place that a break-in period of cycling would really be important would be in a use such as a UPS where you need the battery to be able to perform up to its full potential the very first time it is used (which may be a year or two after installation). There would not be any normal cycling to complete the plate formation enhancement unless you do it deliberately as part of the commissioning.
the "break-in" is not needed before install.... and 5-15 days of 20% cycling should bring the battery to full capacity?[CENTER]SunLight @ Night[/CENTER]Comment
