I was plan to setup a small system in a small shop, but the plan was changed, wife no longer want the solar at her shop. I already bought some of the parts. So I plan to use at one of my fish pond. The pond use one water pump used to run 24/7. but as the electricity get more expensive in Jamaica I have to shut it down a period of time during the night. The pump is 125 watts. I also have one air pump that is about 5 watts that I run 24/7 to keep the water bubble run on a different circuit.
The system is plan to run as long as possible each day, but by calculation it won't run 24/7.
2 240watts solar panels
1 Xantrex Pro Watt SW1000 1000watts pure sine 12volts to 120volts inverter.
1 Tracer 4210 40amps mppt 12/24 volts charge controller.
2 225 Amps 6 volt deep cycle battery
location Mandeville Jamaica. (plenty cloud pass in the day even no rain)
The inverter LVCO is hard coded preset at 10.5 volt. which will kill the battery in a very short time. the original plan for use this inverter with human intervention so should be fine, but now it is to run at the night so no human intervention is available.
What can I do to prevent to batteries get kill by over discharge? at a reasonable price? the pump can be shut off few hours at night without problem. I am thinking may be I should use a longer and smaller pair of battery wire to have a volt drop about 0.5 volt so the inverter sense the volt for 10.5 volt and the battery actually have 11volt? The load is light so it won't have the large fluctuating voltage that make the situation worse.
Thanks
Thanks
