Hi,
Is high charge current to charge the flood acid battery equal to equalization? said if I charge the battery bank once every month with current equals to c6 to c7 rate for an hour or so in bulk charge mood with the inverter/charger. does it equals to equalization? do the same damage and soften the sulfating like the equalization?
The reason I ask is the inverter/charger (Magnum MS4448PAE) need a special control pad to start equalization which I don't have. The outback charge controller have the option to equalize but the PV current is not stable as the clouds always passing where I live. So I try to do it with the inverter/charge with the current from the grid.
Thanks.
Thanks.
