Not IMHO and history says differently. The Market decides, companies just capitalize on the demands.
You are correct the Market demands a better battery. So far Lithium is winning with a huge lead.
Aquion Energy up and coming battery....opinions please
Bruce I agree with what you say about converters. Equipment can be made to work of a 2:1 voltage range. Not at all uncommon. Now put yourself say inside Joe Blow Battery Inverter Manufacture shoes for a minute. Are you going to spend millions to redesign your equipment to work with a queer battery that is way over priced, and take the chance of going bankrupt pricing yourself out of the market passing those cost onto your customers?
our current difficulties with batteries, we should leave no stone unturned. That micro grid
project in HI ought to be a good trial, probably all new equipment. BruceLeave a comment:
If the Aquion is so great why do they only warrant them for 24 months A Walmart battery comes with a 24 moth warrant and no hassle claim. A good FLA like Rolls 5000 comes with 7 years at 1/4 the cost and will last longer until proven wrong. Its no contest.Leave a comment:
And recommend them to those who are both interested in overall long term savings and minimizing impact on the environment.Leave a comment:
Bruce the last 50% of capacity on Aquion battery is not usable once the voltage drops below 40 to 42 volts on a 48 volt system. The Ri of the Aquion battery is so high forces you to significantly over size the battery by 100%. They are completely useless IMHO, and because of that fact they will go bankrupt when the market discovers that fact. I waited 5 years for them to publish specs. What a disappointment. I really feel sorry for their customers.
I know it would work with my system as my heaviest loads go very occasionally to 2000 or Maybe 3000 watts. Even those loads would pose no problem for an AHI system configured for my needs, where I'm using a daily DOD of 20 to 30 %.Leave a comment:
Bruce I agree with what you say about converters. Equipment can be made to work of a 2:1 voltage range. Not at all uncommon. Now put yourself say inside Joe Blow Battery Inverter Manufacture shoes for a minute. Are you going to spend millions to redesign your equipment to work with a queer battery that is way over priced, and take the chance of going bankrupt pricing yourself out of the market passing those cost onto your customers?Leave a comment:
Battery Voltage Range
If in fact the regular cell operating range is 1.25V to 2.45V (1.96:1), Aquion batteries are
a very poor substitute plug in to many existing systems. As I recall most recently we were
designing office equipment to nominally run 39.5V to 54V, with a capability to 60V.
Those were disconnect points.
HOWEVER, the capability to use this range has existed for a while. DC - DC converters with
an input of 36V to 72V are common. Plug ins running on rectified AC will accept 120AC to
240 VAC or anything between. My 7.5KW grid tie inverters have an operating input range of
230V to 500V (with tolerance of 600V). This sort of equipment could run nicely over such
a battery range. So I see this as a matter of bringing the right equipment together; easy for
a brand new design, not so good for current apps.
What I liked most about Aquion, is the ability to tolerate severe DOD for some time without
damage. Lets recommend them to all those people who would wreck their first battery set.
Bruce RoeLeave a comment:
A utility is designed by engineers who know what the batteries can and cannot do and thus the equipment is custom designed to work with the queer discharge curves and low C rate of the battery. The issue is two fold; economics and equipment compatibility. Aquion economics and compatibility do not work for consumer solar markets.Leave a comment:
In the News Aquion Powers Ahead with its Safe, Simple Energy Storage Batteries The Energy Report recently visited our Westmoreland County, Pennsylvania battery factory to see exactly how our saltwater batteries are produced and discuss Aquion’s history and future with Matthew Maroon, Vice President of Product Management One leap off the grid: Melbourne House Installs…
The bottom line is the overall cost of storage, which, if the specs they publish are true, could be the case!And at the same time they are environmentally friendly, which in itself, is a selling feature.
By the way, FLA's are also way over sized in order to provide a long life system. Many off grid users use only 20-30% average daily DOD!Leave a comment:
The point most seem to overlook, is doing lesser Depth of Discharge isn't saving much
money on batteries. Rather, you trade a high DOD on replacing fewer batteries more
often, against a lower DOD of a larger battery bank replaced less often. Just to compare,
12,000 cycles of 25% DOD is total energy stored over life of 3000 times batter capacity.
4000 cy times 80% = 3200. 6000 times 50% = 3000, they are all about the same lifetime
energy stored per battery $. Bruce RoeLeave a comment:
They are too expensive, and their usable voltage range (30V - 59) does not align with off the shelf equipment. Can you get to with that restriction? I don't know.
You are going to use them at 25% DOD? If so, you've got a lot more money than I. And floor space. For me, that could cost $45,000. If 12000 cycles is correct (they advertise 4000 @ 80%, 6000 @ 50%). Maybe long term it works out - too many unknowns and expensive for me.
The system I have is likely not near the size of yours, so the cost to install with 25% DOD would only be a fraction of that cost. Also, a significant price drop is planned at the end of this year from what I have read. I would expect the price to fall over time, just like any new product or technology that makes it's debut.Leave a comment:
It sounds like these S20 stacks could work for many people who are off grid. The reality is that they would have to be sized for one's systems needs, much like is needed with any other battery type. If you have enough stacks in place, you can keep current flows down and the overall efficiency will be high(er). As a result you would be able to keep the DOD low as well and would get even more cycle life out of them. I believe they are rated for about 12000 cycles at a 25% DOD, correct me if I'm wrong? And they don't suffer a sudden death as many other batteries do when they do approach their cycle life. I don't know of any other battery that could compete with this? Couple that with no maintenance, cell balancing, electrolyte changes, etc... required!
It would be great to hear AHI users chime in. I realize they have just come out and there's not many in use at this point.
You are going to use them at 25% DOD? If so, you've got a lot more money than I. And floor space. For me, that could cost $45,000. If 12000 cycles is correct (they advertise 4000 @ 80%, 6000 @ 50%). Maybe long term it works out - too many unknowns and expensive for me.Leave a comment:
Aquion Batteries
It would be great to hear AHI users chime in. I realize they have just come out and there's not many in use at this point.Leave a comment:
