I own a SunCapture 300W folding solar panel and would like to be able to use it to heat water for washing. I would like to be able to heat water and fill an Helio pressurized shower on tour. (https://www.youtube.com/watch?v=DBmafwdPzes) There are all kinds of 12V/24V car immersion heating elements, even DC water heater elements that I could use. Is it as simple as connecting the panel to a heater through an adjustable dc/dc converter and dialing the appropriate voltage? Thanks for any help.
eBike Touring
There are many ways to do this. Some are more efficient than others.
Unfortunately, that solar panel is less than 20% efficient, meaning that it wastes 80% of the sunlight coming on it. The dc/dc converter will waste a bit more. On the positive side, an immersion heater is 100% efficient.
The most effective way to get energy out of a panel is with a maximum power point tracking (MPPT) converter that adjusts its conversion ratio to get as much power as possible out of the panel. A simple DC/DC converter (often called PWM) will also work, but not as efficiently. Both are PWM, but people save that term for the simpler system.
The most efficient solution (60%+ efficient) is to direct the sunlight at a black water collector and let it heat the water directly.7kW Roof PV, APsystems QS1 micros, Nissan Leaf EV -
Unfortunately, that solar panel is less than 20% efficient... I think the SunCapture is more like 23.8% or some such but it really doesn't matter as I already have and use it and it's folding. I use it to charge the 30Ah lithium packs for the bike and a few 12V items like a Fugoo XL speaker. - https://photos.app.goo.gl/rFim5rPsajmDt8NJ6
The most effective way to get energy out of a panel is with a maximum power point tracking (MPPT) converter... Yeah, got one set to 56.8V for the lithium packs plus a Grin adjustable dc/dc converter. I just want to know if it is easily done with what I have and don't care if it's the latest and greatest.
Note: I was wrong...
"HPC SunCapture 300. A 300W portable and foldable solar panel that will power your most prized possesions directly from the Sun! These panels are made with the world's highest efficiency Sunpower Maxeon Gen 3 solar cells purchased here in the United States and provide an energy conversion rate of a whopping 24.2%! These panels are meticulously hand-sewn into heavy-duty waterproof Nylon for a robust yet lightweight folding design."
I would like to argue the use of the word "lightweight" and have to point out that none of my "prized possessions" needs electricity.
Stay safe.
Yes, that is surprisingly efficient. Sorry for my error.
Back to your question - yes, you can simply follow your MPPT converter with a DC/DC down converter. I'm not sure what the Grin is, but if it accepts 56.8V and puts out 12V or 24V, you may be all set. Just make sure that the current level is compatible. In other words, make sure that your heater is 200 watts or less and that your DC/DC converter can put out the current required. I suggest a 200 watt limit because you won't always have full sun.7kW Roof PV, APsystems QS1 micros, Nissan Leaf EVComment
Back to your question - yes, you can simply follow your MPPT converter with a DC/DC down converter. I'm not sure what the Grin is, but if it accepts 56.8V and puts out 12V or 24V, you may be all set. Just make sure that the current level is compatible. In other words, make sure that your heater is 200 watts or less and that your DC/DC converter can put out the current required. I suggest a 200 watt limit because you won't always have full sun.Comment
Yes, you can use the lithium battery into the DC/DC to make 12V for a heater, or anything else that needs 12V DC, as long as it is within the current and power rating of the converter and battery..
The link you showed is for an adjustable DC/DC converter. It mentions a potentiometer to adjust output voltage. That probably means that you need a voltmeter to set the output voltage. If you plan to change output voltage on the road, you may need to carry the meter with you.7kW Roof PV, APsystems QS1 micros, Nissan Leaf EVComment
The link you showed is for an adjustable DC/DC converter. It mentions a potentiometer to adjust output voltage. That probably means that you need a voltmeter to set the output voltage. If you plan to change output voltage on the road, you may need to carry the meter with you.Comment
You are going to be much better off getting a SolarShower bag and use that for heating water. Or a small propane fired water heater to run off a 16 oz tank.
You need to mount the PV panel in the sun for charging the battery to run the heater. Trying to get a MPPT DC-DC converter is a toughie, easier and more reliable to have a battery and use a DC water heater element. then you need a metal tank for the water, so the element does not melt plastic.
good luckPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
good luckComment
