Hi there,
I just purchased a sailboat and its electrical system was put together in questionable ways..
It came with an 815W array of mismatched PV panels, linked to a Xantrex C40 (40A) PWM charge controller, charging a 1030Ah 12V lithium battery bank.
First question: can mismatched panels damage the controller or reduce array efficiency in any way?
Second, I'd like to replace the PWM controller with a Victron MPPT controller (or the like) to boost efficiency... how do I calculate the total voltage/amp rating for the controller given the differing panel specs? Do I simply add the VMP/IMP/etc values together? I guess this would also depend on whether I wire the panels in series or in parallel... suggestions?
The run from panel to controller is relatively short, but would it still be best to wire the panels in series (to 96V) then have the controller step it down to 12V?
The panel specs are as follows:
3x Sun Electronics 95W
(VOC21.2V, VMP17.4V, IMP5.46A, ISC5.99Am)
3x Sun Electronics 90W
(VOC21.2V, VMP17.5V, IMP4.57A, ISC5.6Am)
2x Sun Electronics 130W
(VOC24.1V, VMP19.8, IMP6.55A, ISC7.11Am)
Thanks in advance for your advice!
