Sorry for the long post but all the following information is pertinent.
Having taken advice from forum members I am now in possesion of the above controller but have a question with regards to installation.
I planned to continue using my existing wiring and switching ect. My present install disconnects the controller via a relay when the ignition is switched on and the engine running, and of course reconnects the controller when switched off, this system has worked fine with the PWM for a number of years. I switch off, slide the solar panel out from under the roof rack, plug it into the roof socket job done, now it seems this system may not work with the MPPT controller?
I have read having the MPPT solar supply AND the alternator running at the same time is not an issue, apparently one or the other will just back off the charge rate? Seems logical enough although I have never tried it however, somebody with a MPPT controller has problems.
If I understand the issue correctly it is as follows:
The battery/s had been receiving a lengthy charge from the MPPT which had reduced charge voltage to 'float', then the engine was started and the alternator raised the voltage over and above the float charge. It then seems that later after some period of 'alternator time' the engine was switched off, from then onwards the controller would not return to bulk charge regardless of how low the batteries were, the owner found by disconnecting the controller from the batteries and then reconnecting the controller returned to normal operation, start the engine at a later date when the controller is in float mode and the problem repeats itself.
So, will it do any harm switching the Victron 75/15 MPPT type of controller as per my old install? Assume diode protected relays throughout this install and any other accessory I have installed.
Many thanks.
Many thanks.
