Originally posted by Yet another Yeti
Rate this 200w panel compared to two renogy 100w panels
With mppt the higher the imp volts it has to down convert the less efficient it will be. With 2 100 panels 38 or so to 12 is less efficient than the 200 watt 21 to 12. The loss would be in heat in the controller. And if your gonna later want 300 watts keep all the panels the same. Different imp vmp panels cost you power also.
Fwiw if you use 100 watt renogy panels get the latest slim design. They are lower vmp and higher imp. They gave me a couple more amps vs 18.9 5.29 old style panels on a 300 watt system. But use only on mppt controller. Imo vmp on the slims are to low for parallel with pwm in 90f temps.Last edited by Ho jo; 02-28-2019, 04:14 PM.Comment
