Opinions sought on panel charge controller.
  • DMH
    • Jan 2019
    • 35
    Hi all, first post and seeking advice, well nothing new there right? 8>)
    Whilst waiting for my account activation I posted this question on one of the off road forums that has a solar power section, now having access I would like to hear from forum members who can no doubt draw from broader experiences.
    For various reasons I had to change the solar panels on my off road 4x4, there were 2 x 100w panels, one fitted horizontsl to the roof rack and the second on a wandering lead of about 15 metres, both panels were wired in parallel to a 20 amp PWM type controller. Those panels maintained two marine wet cell batteries or around 3 years with no real problems. I only have a small 50 litre fridge to keep working, it draws around 4 amps, but of course only a few minutes out of each hour. On odd occasions when camping and getting two consecutive days of poor sunlight did I consider running the engine but with the VSR protecting the start battery I decided to leave be and sure enough no problems.
    Those 2 panels are to be replaced by 2 of the spec seen in the picture above. The difference is now that both are to be fitted to the roof rack and both will be horizontal, given there will be less cable length in use, but no ability to track the sun, would there be any mileage in swapping the PWM controller for an MPPT type but still wired in parallel?
    BTW, I tried a medium size picture but could not read the spec, hence the large size.
    Any thoughts would be appreciated.
    regards
    Dave
    • 15208
    With 150 watts and an MPPT you may generate about 12 amps max. (150w / 12v = 12.5a) no matter how they are wired as long as you don't exceed the maximum DC input voltage of the CC.
    With a panel Voc = 21.4v you could generate 42.8 volts x 1.15 = 49.2volts depending on the temperature. If your MPPT CC has an input DC rating of 100V you will be ok. If it has a max DC input of 50v you may exceed it during cold weather.
    Wiring those panels in parallel to a PWM type CC will get you about 9 amps max ( 2 x 4.45amp = 8.9amps). That calculates to just over 100 watts (8.9a x 12v = 106.8w) so you would be losing about 33% of your panel wattage.
    It depends on the cost of the MPPT compared to losing 50watts of generation.
    • DMH
      • Jan 2019
      • 35
      Thanks for the reply and information. A basic MPPT to cover 20 amps is only around 20 euros, I will look at the specs and see if they are suitable. 33% is worth the effort to purchase and swap out the PWM IMO.
      Thanks again,
      regards
      Dave
      • Raul
        • 258
        No it's not 20 euros, those are fake. Don't throw your money away; for 20 you not going to get not even a real pwm. A real mppt at 20A starts in the region of 75-80 euros.
        Look at victron blue solar charges to have a idea of the cost of a real mppt. There are others on EU market as well.
        • DMH
          • Jan 2019
          • 35
          Hi Raul, I will take your comments on board. The PWM I presently have is a typical ebay unit, TBH it has performed how I thought it should over the last three years, I based my purchase consideration on this and ordered a cheap MPPT unit from ebay. In your opinion this is going to be a waste of money on my 4x4?
          regards
          Dave
          • DMH
            • Jan 2019
            • 35
            Hi, I have looked at the Victron range and
            • littleharbor
              • Jan 2016
              • 1998
              There are a number of fake MPPT charge controllers on eBay but, there are plenty of decent fairly inexpensive models out there as well. Look at the EPEver line of controllers There are many contributors on this forum who use them and they are what they say they are.
              • DMH
                • Jan 2019
                • 35
                Hi and thanks for that. I did write in my last post about seeing fakes with mission critical products however half the post disappeared?
                I noted I had seen s Victron unit for around
                • DMH
                  • Jan 2019
                  • 35
                  OK there is a problem with my account, a large portion of my posts are not appearing?
                  Mods?
                  Regards
                  Dave
                    • 15208
                    Mods?
                    Regards
                    Dave
                    Sometimes the post will be cut off if you "paste" a lot of text. Another way our software cuts off a post is if you use an apostrophe. For some reason it takes that character as spam.
                    • DMH
                      • Jan 2019
                      • 35
                      Hi and thanks for the quick response.
                      I did not cut and paste anything but did use open and closed brackets, sound familiar?
                      regards
                      Dave
                        using brakets is bad, they delimit a lot of things on message boards [
                          • 5246
                          Sometimes cut and paste fails for me, so I type a few letters. At that point the cut and paste works,
                          I go back and delete any extra letters. Bruce Roe
                          • DMH
                            • Jan 2019
                            • 35
                            Thanks for that guys, I will try to remember that. As I had already purchased the MPPT cheap from ebay when I saw the post from Raul, and I now have two brands to choose from. FWIW I did connect the two new panels in parallel to the PWM, and with the midday sun low in the sky I did see 2 amps from each panel as they laid flat on the roof, if nothing else it show the panels are working.
                            Thanks to all who have offered help, the plsn is to fit the cheap MPPT, as it is the same size as the present one, I will not have to alter my power distribution setup. As I am in the fortunate position to be able to swap connections from PWM to MPPT in a moment, I may try that? If I have no measurable advantage I may purchase one of the more expensive units.
                            I will update at a later date,
                            Thanks again
                            Regards
                            Dave
                              Mods?
                              Regards
                              Dave
                              Most important, do not use "smart quotes" where the opening and closing quote marks are different symbols. The occurrence of a smart quote character can truncate your post.
                              The smart quotes are represented by a multiple byte sequence and one of those byte values is not allowed in a post.
