Hello, new member here. I am in the early stages of planning and acquiring components to add a solar system to my school bus RV conversion. Unfortunately I found this forum and the information herein after purchasing a few components at a deep discount. First I purchased 4 245w Bosch Mono PV panels. Voc = 37.27, Isc = 8.61. Then I purchased a Xantrex Freedom 458 MSW 12 volt inverter (2500 watt). My plan is to run the majority of my RV appliances on 12 VDC, with only a few components/outlets on 120 VAC. Now that I have read the stickied posts I'm learning a lot of things about mistakes I have already made in my planning.
My initial plan was
(4) 245w PV panels wired in 4p *already purchased*
(1) Midnite Solar Classic 150.
12v battery bank
(1) Xantrex 458 MSW 12v inverter (2500w) *already purchased*
Are there any concerns with wiring all 4 panels in parallel? It has been my understanding that parallel wiring helps to prevent losses due to partial panel shading. As always with electricity I know I would have to ensure adequate wire size. I think to the CC it would have to handle ~40A (8.61A * 4 = ~35A).
For the MPPT CC, I was planning on purchasing a Midnite Solar Classic 150 when I get closer to the install date, as it is the only CC I've found that can handle the amperage necessary to run a 12V system with my panel wattage. 980w/12v = 81A necessary. Midnite Solar Classic 150 can handle 96A.
Concerning the battery bank, I have not purchased anything and so can buy whatever is necessary for a safe system. As I understand if I use a 12V system I should have at least 720ah of FLA or 360ah of AGM. I was planning on AGM as I could mount them inside without danger of offgassing and they are maintenance free. If the FLA is a much better buy I can build underbody battery storage.
I also read that a big problem is having an 12v inverter over 1000 watts. Before I found this forum, I purchased a used Xantrex Freedom 458 (2500 watt) fairly cheap. I'm hoping that there is a way to use it without creating a hazard to my family and I. Is there some way to ensure that I don't exceed the recommended 1000 watts and make it safe for use? If there is not I dont have any qualms about selling it as I got it pretty cheap, I had just heard good things about the company and thought it was a good deal.
Please don't pull any punches, I've got thick skin.
~Alf
My initial plan was
12v battery bank
~Alf
