I am basically void of any solar charging systems. I would like to be able to set up a solar charging station for my sailplane batteries. I would like be be able to charge 6 or so batteries that we use in our glider club. These batteries are of the K2 type and are 12 volt 9.6 AH. I need to know what complete system would be the best for our needs. Panel, controller and any other advice that you could offer.
Need Advice On Solar System
The K2 is a LiFePo type battery which will require some type of BMS charging system so a standard battery charger won't work.
You can build a solar / battery charging system and then use a DC to AC inverter if your BMS system requires AC power to work or if your BMS uses 12V DC then you can connect it directly to a larger battery.
You can build a small solar / battery system using a 100 watt panel , 10amp PWM CC and a deep cycle 12volt 55Ah battery which should be able to run a DC BMS or AC inverter for about $400. -
for $100 you can get a deep cycle marine battery and use an ordinary car charger to keep it topped off between weekends.
Or you can get a 200W panel, build a frame for it, figure how to transport it, buy the same $100 marine deep cycle battery and a $100 charge controller, a handful of fuses and a bundle of wire. And if it is a cloudy day, you still get to use the car charger to recharge the battery, because if you let a lead acid battery sit <90% charged more than 24hr, it will sulfate and begin to die.
A "dashboard" 10W solar panel will not be sufficient to do the jobPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
I spent about $550 on this system but $250 of that was for the 80watt folding panel which I am sure you can get for less.
It also has a 65Ah Blue Optima battery which is more than you would need so again you can save some $ getting a smaller battery.
The cart, battery box and a 250watt inverter may cost you about $50 so IMO $400 should get you something similar to what I have.
Or you can follow Mike's advice and just get a battery and standard charger for a lot less and just forget the solar part.You do not have permission to view this gallery.
This gallery has 3 photos.Comment
