Announcement
No announcement yet.
Cheap watt meters & high constant loads?
  • Filter
  • Cheap watt meters & high constant loads?
    I have two of these watt meters attached to my portable battery for input (solar & charger) & output to just know how many AH I use & put back in. At the time they were cheap & easy to use & I was only running a few fridges & LEDS.
    Now I have beefed up the solar to 500watts which is around 40amps, plus I now have an inverter using up to 30+amps.
    There does not seem to be any clear answer on how much these things can handle in the instructions, mine seems to say it can handle 75A continuous. The small cables are 12Ga wire.
    So can anyone say what the safe continuous amp rating on these things would be? Would they drop the voltage too much?
  • #2
    To handle 75amps continuously you really need wires & insulation sized to handle more than that. If the wires that are connected to that meter are really #12 AWG I seriously doubt they will handle 75amps running through them. More than likely they will get very hot and you will see the insulation deform, melt or worse burn.
    • #3
      As long as they can handle 40amps. But i think no way of knowing in my situation. Yep they are all 12ga about 5cm long.
      Looking for heavy duty rated watt meters.
      edit: found a 200amp unit that reads 50amp continuous using 8ga wire. Perhaps being so short the wire cam handle it.
      • #4
        Something funny about wires. If they are exposed to high currents over a period of time the insulation tends to get brittle and at some point the metal of the wire becomes what we call a "fuse" because it melts.
        • #5
          Length makes no difference. FUSING CURRENT on 8 AWG is 472 amps. Maximum load current in free air is 55 amps on 90 degree insulation. .
          • #6
            ....Perhaps being so short the wire cam handle it.
            Length of the wire has no effect on the current carrying capacity, it's still n Ohms per inch. Enough amps and the ohms causes heat, 1" or 6 feet
            • #7
              Thanks. Well that says to me these watt meters are not safe at their fony advertised rate. I guess if the wire stays cool all is fine. Can the wires get luke warm? No way for me to know if these meters drop voltage.
              if someone could direct me to proper high
              cutrent compact watt meters. Please.
              • #8
                This little AC/DC ammeter works great and appears to fit your needs.
                Uni-T B4Q094 UT210E True RMS AC/DC Current Mini Clamp M W Capacitance Tester https://www.amazon.com/dp/B00O1Q2HOQ..._fE7lBbXMX3AST
                • #9
                  Problem is it has to be a full install sitting in between battery & CC & battery & load. That device runs on batteries by the looks & its for temp use.
                  • #10
                    So from all the searching these watt meters are not really suppose to be used inline permanently which sucks as there is nothing else out there. The ones i have use 8ga wire and say they can hanlde 50amps continuously.
                    my highest loads will be 35amps from CC (maybe 41 if i go bigger panels). So will this be fine?
                    I worried about voltage drop which would effect CC's performances and possibly mean battery not fully charged.
                    But at 20 - 22amps constant there looks to be an average 0.08v drop using my cheap multimeter. Not sure if that is reliable and what the loss will be at 40amps.
