I want to run this past someone who knows if this will works like I think it should. If I mount two 300 watt panels on the roof in parallel producing 41.2 volts, and then also add two 100 watt portable panels in series producing 47.3 volts into the same 100 volt 50 amp controller. I would have ~88.5 volts going to the controller and between < 16.7 + < 50.6 amps as the output to the battery. (cut off by the controller at max 50 amps if the two flat panels on the roof can get anywhere near that wattage)
My question is the voltage combined (added together) and the amperage combined to raise the output amperage too? Thanks, Bill
