We bought our first motorhome last summer - kind of an impulse buy off a family member that was going to trade it in - a class c 1994 Conquest 102. A friend from work was telling me that they have one and it has a solar setup on it which is really nice. A couple weeks ago I saw a good deal on some solar panels and started researching what all we would have to buy to add solar to an RV. I think I did OK on my research and purchasing... Ended up with this stuff:
2 x Grape Solar 100-Watt Poly solar panel from Home Depot (5.56 amp)
Allpowers 20A Solar Charge Controller (PWM) from Amazon
2 sets of Z-Bracket for solar panel roof mounting from Amazon
5 pair of Renogy MC4 male/female cable connectors from Amazon
10-pack of ATC in-line fuse holders + 30 amp fuses + 40 amp fuses from Amazon
Power TechON 600W pure sine wave inverter from Amazon
During my research and purchasing our motorhome was parked at our family's house for the winter. After picking up the motorhome and poking around I realized that although I figured out what to buy I actually have no idea how to actually hook it up to my RV...
Looking for advice on where to start digging and if I need to purchase anything else. What I have now on the motorhome:
2 batteries both under the hood - one for driving and one for the motorhome... Unsure of the aH of the battery
30 amp plug
Generator
I assume a converter somewhere as the generator / plug charges the battery
Goal:
- Learn about solar for a potential addition to our home
- Significantly reduce generator usage when boondocking
- Have at least some 110v A/C available without needing to run the generator (that's alternating current not air conditioning)
- Ideally be able to run a 19" LCD TV and DVD player (or raspberry pi) when boondocking (again with minimal generator usage)
- Note, we're a family of 6 that is used to tent camping... I don't anticipate that our electric needs are very high (we don't shower in the RV, aren't using laptops, etc)
Specific questions:
1. Did I completely miss on any of my purchases (did I buy something dumb or miss buying something I'll need other than the actual wire)
2. Do I need more battery
3. Where in my system do I hook this up??? (I'm assuming this is a bigger question and I'll have to figure out more about my setup but I need help there)
4. What locations do I fuse? I knew for sure I fuse before and after the charge controller and between the battery and inverter. Read recently that I might need to fuse each panel independently if wiring in parallel - sound right? Anywhere else?
5. Is 8 AWG wire adequate for all the wire runs? I'm most unsure of the wire between battery and inverter
6. I *think* I sized everything so I can add a third 100W panel at a later date
I realize I probably need a lot of help and would really appreciate any guidance you guys are willing to provide
30 amp plug
Generator
Goal:
Specific questions:
