New guy here trying to setup my RV for off grid boondocking.
Here is what I have:
5 Sharp 123w panels 21v 7.3a
4 Kyrocia 51w panels 21v 3.1a
1 Tristar TS-60 PWM charge controller
1 20a solar PWM charge controller
Onboard Onan Emerald ! 4kw generator
Honda eu1000i generator
Aims 1500w inverter/charger with transfer switch
Aims 3000w inverter charger with transfer switch
The RV alternator also charges the batteries while underway
I also have a morningstar RD-1 Relay device with 4 channels
8 Trojan 6v 105 golf cart battery bank 12v.
Loads:
1 mini split A/C unit 5000btu (homemade from window unit) 450w 4a draw
Colman 15000btu RV air conditioner unsure of watts and likely a 10 11 amp draw.
RV microwave
Home mini tower with 750w supply
42" Plasma TV
70's Pioneer quadraphonic receiver (aprox 100w audio power not sure on the 110v input power)
I run other stuff but this is the main loads and I can not use the Microwave and the AC at the same time. I can run any of the other stuff in combination with either the AC or the Microwave.
Here is what I want to do:
Modify the Honda eu1000i for electric start, so I can use it to supply current to the battery bank when I run the small 450w AC unit at night once the bank falls to 60% Using the Aims 1500w inverter/charger and the RD-1 relay control.
Because I live in Texas mostly and it gets very hot and humid.
If I'm running the whole RV I want to do the same using the Onan and the Aims 3000w inverter charger.
Because I can run the generators I use the aprox 800w solar and aprox 800ah battery bank to supplement them.
There is a mismatch in current on the PV panels so I'm not sure if I can use the one tristar to control them all or I should use the tristar only on the bigger panels and the other little controller on the smaller panels?
There really is no room on the roof for more panels.
Any thoughts?
Monroe
Loads:
RV microwave
42" Plasma TV
Any thoughts?
Monroe
