You will need to configure the MPPT controller to work with a Wind Turbine. That changes in interernal IV curve to work with copper windings and not PV panels.. Not all MPPT controllers are adaptable.
What's the 36V amperage ? Age of the engine? sometimes lightly loaded diesels will Wet Stack and get gummed up under light loads
DC generator to charge my RV house batteries?
You do not need any charger or MPPT if the genny has a 36 volt DC output. Only real issue is 36 volts DC is a bit to low to charger with on a genny, and no charge or controller is going to fix that, just make it worse and take longer. Besides a MPPT controller would not work.Last edited by Sunking; 04-17-2018, 04:47 PM.Leave a comment:
Hello Everyone,
I am installing solar and upgraded house batteries in my RV. I will have a 24v - 370A/H battery bank and need backup charging for times when solar production is not adequate.
I have come across a diesel 36v generator. Basically a small diesel motor with a 36 volt alternator.
What I am considering is using the 36 VDC generator to feed a 40A MPPT charge controller to charge my 24v battery bank.
My RV is diesel and I don't want to have to carry gasoline. Otherwise I would buy a little Honda inverter generator.
What do you all think of this plan? Suggestions?
Thanks.
S.Last edited by PNW_Steve; 04-17-2018, 07:28 PM.
