Putting together my first solar off grid system. Im 59 years young and this is my first attempt. . So far I have been using the Renogy brand. I wanted to give it a try, so putting together a 300W system together for my green house.. My desire to run fans, grow lights. I would like to run a a heater in winter months but from what I have read I have my doubts I can do that with what I have . So far I have placed a 40amp mppt charge controller with remote trace meter, 2000w inverter. On the way are 3- 100w monocrystaline panels and 2- AMG 12v 100ah deep cycle acid batteries. . I HOPE this is a good setup. I would like some info on where to place fuses and what size. I know one should be between controller and batteries, and one between batteries and converter. ANY and all help of information would be greatly appreciated. Thank you / Ken
Very Very New check my work please
Well the good news is that with 300 w of panels, a 12v 200Ah battery and an MPPT CC you have a nicely balanced system
The bad news is that battery system is rated 2400 watt hours (12v x 200Ah = 2400) and you could probably get about 600 wh or 25% DOD each day. I don't know what you need to run your fans lights, etc but 600 wh is not much. -
I'd suggest learning and studying more before you proceed further.Comment
Have a watt meter.. The fan ( if I recall correctly ) .45 watts. It only runs when greenhouse gets over 100 degrees. so time it runs is limited to heat of the day. The grow lights are led and I have not tested them with a meter yet, Also limited about of time 2 - 3 hours in winter months. Any advice on fuses ? What upgrades might I need to grow later on ? 3rd battery ?Comment
Also should a trickle charge the batteries until full before using them? I have head reg car battery chargers are too aggressive of a charge ??Last edited by carolinaken; 03-22-2018, 06:24 AM.Comment
I use an old fashioned kerosene railroad lamp for keeping the greenhouse above freezing in the winter.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
You are correct though that full batteries are happy batteries. Periodicly monitor their state of charge, and get them fully charged any way you can byweekly or so.
Did you mean your fan uses 45watts? I seriously doubt the .45watt value. Two amps at 12V would produce the needed power, and 10 hours of the fan running would consume ~1/10 of your total capacity.Comment
Stop what you are doing. It is not going to work because everything is grossly undersized.MSEE, PEComment
Sunking and Suneagle can discuss... -- Suneagle --Well the good news is that with 300 w of panels, a 12v 200Ah battery and an MPPT CC you have a nicely balanced system. I think Im fine just to run a fan and a few led light at random if not.. Solar is over ratedComment
Depending on what that fan and led light actually consumes will determine if that system will work or not. Remember it may only provide about 600 watt hours each day which is easy to use up depending on how you really run your loads.
By the way I build a small solar / battery system for about $2500 and it barely provides me 700 watt hours a day.Comment
A 300 watt panel with a 12 volt 200 AH battery will provide you roughly 500 to 700 watt hours of electricity per day in summer and far less in winter. That is less than 10-cents of electricity per day.
First issue you have is your inverter is grossly over sized for your panel and batteries. Your batteries can only handle a 500 watt inverter. Next issue is you have no clue of how much power you need in a day. 500 to 700 watt hours might work, or might not. No one knows because you have not told us. Lets do some simple math.
Watt Hours = Watts x Hours. simple 5th grade math.
So if you have say a 50 watt fan and run it for 10 hours = 50 watts x 10 hours = 500 watt hours.
So now your job is to figure out how much power you will use in a day worse case. You have to determine how much power in watts all the motors and light use, and how many hours per they wil be used. Example if they add up to say 300 watts, and you want to run them 10 hours per day you are SOL because 300 watts x 10 hours = 3000 watt hours or 6 times more than your system can deliver. With a 300 watt load only gives you 1.5 to 2 hours run time.
Forget the heat idea, it is not going to happen.
MSEE, PEComment
SunKing / Thanks for the info == Knew the heat was not going to happen as why I have ac in the green house . I run an oil filled heater presently. Checked the watts on the fan today 97 watts on high setting. It ran 4 times today for no longer then 5 minutes. in 8 hours. It was not a very hot day. Not sure im getting what I should from my panels as Im not sure what numbers I should have ,, On control panel below panel icon / 20.9v - 2.4 amp.. battery icon 13.8v 3.0 a. I do have and old 350watt inverter I can switch to.Comment
What i hoped to get with this system .. first of all.-- just to try solar and get my feet wet.. goals are,, run fan in summer and lights / maybe / in winter..the greenhouse is a new build and Im not sure what my exact times will be for fan or lighting . I have to see how things go with the green house and the solar combined.. both are new .Comment
