Currently have a Transit connect with a 310w panel, Midnite Solar Classic Kid controller, 2 x crown AGM 6CRV220s, and a Samlex ACR-160 between the starter battery and the deep cycle bank.
I've just picked up a new 4x4 Sprinter, and am planning the solar system, but would like to go lithium. I'd like to go to 400AH to start, but be able to add more later. What are some good recommendations for lithiums? I've seen Battle Born tossed around a lot. I've also seen Prismatics for about 25% cheaper, but they are LiFeMnPO4, what's the difference with that and LiFePO4? What else do you guys recommend, or other things I should consider?
Can I have it so this bank is charged off the alternator like my current setup? Right now the Samlex keeps them isolated unitl one side reaches a nominal voltage and then whichever side is charging then proceeds to charge both. Can you do that with different battery types?
Cheers,
Alex
Cheers,
Alex
