Hello all, I need some help for charging Lithium off solar.
I'm Looking to build a small portable camping setup using two Fusion Lifep04 100ah batteries that each has its own built in bms. Keeping them separate & charging one at a time using one or at times two 250watt panels in parallel.
The specs of battery say min charge current is 10amp, std 30, & max 70.
So is there a problem with not getting much sunlight? If I had a single 250watt panel that can deliver up to 12amps max per hour. But it's not going to always get that much. In fact most times there are clouds. And the angle of sunrays are not straight on.
So does this mean to properly charge the battery I would need to be constantly over 10amps charge current?
That 10amp miniumum sounds like a threshold on/off in the circuit & that the battery will only charge in full sunlight.
Another problem is finding a small PWM lithium regulator? I read that the regulator might not work well with the batteries bms, not sure what that really means.
Can someone suggest some cost effective waterproof PWM or MPPT Lithium regulators.
Finally given that lithium likes to stay at around 50-60%SoC & that there are appliances constantly drawing power like fridges, I thought two separate batteries in their own carry box with own regulator are better than one large battery, or else a single large battery will stay in a high SoC throughout a trip. So I would charge one fully then disconnect solar input right before running a slow drawing appliance, while the other battery is being charged up on it's own.
This along with lithium's fast charge time would seem to work well with my set & forget panel approach where panels are only going to get 2-3hrs of light a day max. Do you think this is a good strategy?
Please advise me, thanks
