Hello Everyone, I'm making a new post for my cargo trailer of what I have completed on it, what I have plans for and something to follow as the build continues. My plan for this build/trailer was to have a trailer that is very multi use in all uses in my life from camping, hauling power sports ( Atv, dirtbikes, sleds ) Moving stuff, ect.. My main use is to haul my dirt bikes and quad, as well stay in it as a camper for the weekends for me and the girlfriend.
Starting the build I have a 16x7 Cargo trailer. My Solar set up is 2x 320 Watt Solar Panels wired in parallel, Epever Traccer 40A MPPT charge controller, Matrix 1000W Pure Sine Inverter, 2x 305 AH Trojan 6v Batteries, Blue Sea Fuse Panel
We started with building the Lower cabinets just to the door frame of the door to make the cabinets as big as possible, but not losing too much space inside the trailer for total length. We did our framing with 1x1s, they are cheap, very strong and easy to work with.
IMG_8962 by
IMG_8964 by
I built a chassis grounding bar to make it easier to run all my grounds too. Goes down below to the frame rail of the trailer.
IMG_8983 by
Inverter, Charge Controller, Ground Bar all mounted
IMG_8984 by
Master Switch, Blue Sea Double Fuse Block
IMG_9065 by
System Fully Charged with good sun light
IMG_9010 by
IMG_9040 by
Here is a temp panel to mount my switchs, volt meter, usb plus, 12volt plug and my MT-50 screen.
IMG_9009 by
So far this is what is done. I will be adding shelves, cabinet doors and other cabinets up top. I have been out 2 weekends in a row and the system is working great to power the fridge 24/7 and using any 110v power we need. One thing I need is to tune and edit some of the settings on my MT-50 to charge my system right. I edited the battery type to flooded and AH to 305, but that is as far as I got, can anyone else help me with the other settings I need?
Follow this thread for a cool build, I will be updating as I go with info and pictures.
IMG_8962 by
IMG_8964 by
IMG_8983 by
IMG_8984 by
IMG_9065 by
IMG_9010 by
IMG_9040 by
IMG_9009 by
