First make sure water level is OK. Then charge to 14.5 volts until current stops, rest, then EQ.
Use whatever charger you want. Ideally you want one that charges at C/10 or as close as you can get it. Below C/12 and it takes too long and will not gas the batteries. Crowns are pretty good and can handle up to a C/6 with no issue.
What I am driving at is charge as fast as you can so you are not doing this for 2 or more days. C/10 to C/6 is good. Just note the EQ could take up to 24 hours. So make sure you do a regular full charge first. That should cut the time down by half or more on EQ.
