Airstream 1967 off grid plan
It happens all the time in the US. We were at a very good Colorado State Park and the air conditioning had severe problems. An RV tech came out to our site and said that when a lot of folks turn on their air conditioning at the same time that spikes can occur that will really do a number on the electronics. So we got a surge protector such as Sun Eagle suggested. We got rid of it since we just run line power through a battery charger as noted above.
Reed and ElaineComment
My plan is not to travel in my Airstream, but to set it up as home for maybe half the year. I have 3 adult children that I could spend a month with each and then also travel to another part of the world for 3 months at a time, like Italy, Northern Thailand, Siberia and so on. I think I would be home when it is warm outside, grow a garden and enjoy where I am parked. If I could make it off grid then so much the better. If it was only for 6 months a year, it might be more feasible.
Our three kids have a place for us to park in the back. Our older son (the solar contractor and master electrician) has installed 30 amp outlets at two of their places, which we no longer require. He is off grid but at 7800' in northern NM so electrical power is not required. We spend time with them between other travels and then they come to spend time with us in mountain west and Yucatan. We had Roadtrek in Yucatan this year and took down a 12' diameter rainfly/mosquito shelter for them to stay in. So consider traveling in such a manner that the kids and grandkids can spend time with you.
MSEE, PEComment
Sorry, brownouts, but they can be common. We were at St. Mary's Cove in Nova Scotia eight years and someone turned on three of their air conditioners at the same time and that took out the breakers for the entire RV park. They do not usually have folks turning on air conditioning there.Comment
Well that certainly reduces your requirements. If you use LEDs and cook and refrigerate with propane than you really do not need that much solar/battery capacity.Comment
Propane water heater or solar? I was hoping to avoid propane, but It is doable wherever one goes.Comment
How much hot water do you anticipate needing ? And, how steady or consistent on a daily basis is the solar resource ? If you need a lot of hot H2O every day in an area w/ questionable, low or inconsistent sun, get propane. If you can work hot H2O demand around sunshine availability, solar can be useful, but not as reliable as propane.Comment
(Heat pump type water heater is also much more efficient if you want to put all of your eggs into one PV system.) If using resistance heating, heat your water later during the day when your battery bank is not able to soak up all the energy your panels can deliver.)
Propane refrigerators are very energy inefficient, but your solar PV is a lot more expensive than grid power.SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
Guessing this has been mentioned by this point, I haven't read past the first page of the thread yet, but a wind turbine is a no no for an RV because of vibration. When they're engaged there's a deep rumble vibration that transfers to the structure it's attached to. If you're going to use it, you'll need to mount it away from the camper, or you won't be able to sleep.
You also need to get it up above any gusts, but that part is less important, since it'll still produce power at lower heights, it'll just continually engage and disengage, making the noise issue even worse.Comment
MSEE, PEComment
If you want to heat your water with the sun, you are better off putting in enough solar thermal panels than trying to use electric resistance heat.
MSEE, PEComment
