I have a relatively new lifepo4 12v solar setup which under charge is only reaching around 13.36V and then it slows down so much it may as well have stopped. It's never reaching the absorb or float stages. It seems to be very slow even getting to this point.
I've dismantled the setup and the settled battery charge is now 13.25.
It was 13.5 when it arrived from the store
The programmable Victron charger 75/15 has worked flawlessly on my SLA setup, so I'm hesitant to think this is the problem.
I am charging at 14.6 floating at 13.6, temp compensation and equalisation is off.
Battery is an EV power 60Ah with BMS and BCU
I have tested with and without the BCU - no difference.
BMS shows balanced cells
Panel is 120W with plenty of tropical sun to play with. I've tested with another panel - no change. Both are outputting above spec.
Obviously I need to test with a different charge controller and rule this out, but there aren't a lot of options where I am other than buying a new one which I would like to avoid.
Does any of this sound indicative of a known problem?
Thanks
Thanks
