Need help building off grid koi pond circulation system.
So, pumps circulate water through the filters, but how is it oxygenated ? Waterfall ? Airstone and air pump ?
360Watt-hours would be 30 Ah for a 12V system.
But you don't want to run a charger out there every day it's cloudy, so you need to multiply that by the number of days you'll potentially be without sun.
BTW I didn't see battery charger on your shopping list - you'll need one for when it's cloudy for too many days in a row.
And I think the off-grid guys recommend getting a temp corrected hydrometer (fairly inexpensive I think)
(assuming I found the same ones you're looking at)
5W * 12 hours * 4 pumps is 240 watt-hours.
the 5W/12V usage of them is going to be only 240gph per pump.
So with 5 pumps you're only at 1200gph
And for 12 hours you're down to 240gph.
Is that sufficient?
Then one pump will run @5v 24 hours a day, so that's 120 Watt hours, for a grand total of 360 Watt hours?
So what is that in Ah?
Keep in mind that any KWH taken from a battery costs at least 5 times that from the PoCo. That, to replace the battery, which has
a maximum cycle life. If you can design so that as much as possible power flows directly to your pumps, and a MINIMUM is charged
and then discharged from the battery, you will minimize your battery replacement costs. Bruce RoeLeave a comment:
This is good stuff. Can we revisit that math? I don't know how to use your calculations with my numbers but I'm going to take a stab at it.
I'll be running four pumps @5V 12 hours a day so that's 240 Watt hours?
There is no inverter since I'm using 12V fountain pumps.
The Koi are very inactive during the coldest darkest months of the year, so I could probably get away with running the first four pumps even less. Perhaps as little as three hours a day. I switch from feeding them twice a day in the summer to feeding them once every five days in the winter.
I think you are corroborating SunEagle's comments - I should be able to get away with 2 panels and two batteries.
But to restrict your daily discharge cycle to 20% of capacity would require 150AH of battery.
From there you can figure in any efficiency losses in your inverter if they are 120V pumps (which I see there aren't) and comparable efficiency losses in the recharging process when calculating the panel size.
All of these calculations are covered in great detail in sticky threads in the Off Grid topic area of the forum. Including some spreadsheets to do the math for you.
P.S. You have taken the single most important step by figuring out just what your planned daily power load will be.Leave a comment:
1. For your small pool pumps you may be able to replace them with pumps that run off low voltage AC or DC (like the 12V landscape lights) The burial requirement for such limited power wiring may be a lot less.
2. If your pumps take 25W total and run for 24 hours each day that would be 600 watt hours.
To put 600 watt hours back into your battery (assuming a perfect inverter and charger) would take about 300W of panel power in the winter when you only get about 2 effective sun hours per day.
3. To supply 600Wh (50amp hours, AH) at 12V safely and sustainably would require a 250AH 12V battery bank. And you would need a way to recharge the batteries manually when the weather is bad for several days in a row.
4. 300W of panel would only keep you even each day. To assure recharge after one or two cloudy days would take 450W of panel or more.
That 100 watt panel can barely support a 55Ah battery. The formula for battery charging is between C/8 and C/12 where C = battery Ah rating. A C/10 is the sweet spot for FLA type batteries. So most 100 watt panels have an Imp = 5.5 amps which calculates out to a 55Ah battery which can maybe get you 165watt hours a day (12v x 55Ah x 25% = 165wh). You need more than that so figure a bigger battery and solar panel wattage accordingly.
What is the Ah rating of those Sams club?
I don't know what the Ah is on the $90 deep cell batteries, I'm going to have to stop into the store and look. I bought a $120 deep cell battery for my RV last year and it was rated at 231 Ah, which seems pretty high but that's what the label said. Based on what you're saying, I shouldn't get the deep cell, I should get two golf cart batteries and two solar panels. Does that sound right?
I don't mind replacing a pair of batteries every four or five years. If I did the math right, it currently costs $24 a month for the electricity to power the 2000GPH pump in my pond. That translates into roughly $300 a year. Over four years that becomes $1200. I can afford to spend $200 on batteries every four or five years if I'm saving $1200 to $1500 in that same time period.
If it's a hardwired system, probably they could require a permit, but won't bother.
What does AHJ stand for?
(Usually permit dept of your city, but outside of cities it could be county or even a state government department/entity
It would cost more and be less efficient. The prepackaged systems I looked at all had small battery packs (I'm guessing they have a few rechargeable C or D batteries inside). Each prepackaged system came with a super simple charge controller. Each prepackaged system had a 25 or 40 watt solar panel. These systems had a flow of about 160 GPH. I would need to buy ten of these systems. I would need to mount ten panels and create space for ten battery packs and a rats nest of wires. I would have to make room inside the bog pond for ten pumps where I really only have room for about six.
I'd check the manufacturer's website.
The frustration is that this audience assumes I haven't already thought of this. I have looked at this problem for several months and running wires was my first choice.
A solar setup is definitely going to mean buying batteries every 1-5 years.
This is actually a good suggestion, but even six inches down is a lot of work in my backyard.
That said, if I can locate a machine to push the wire into the dirt I might be able to get it down there right after a rainstorm. I know my neighbor rented one when I lived in Ohio. I don't know what they are called.
There is the option of using a soaker hose for an hour to get the dirt softened up.
Although hopefully you'll be getting some rain today/tomorrow
I still think it would be cheaper and easier to do the system I detailed above.
I'm not the right person to give advice on battery systems and PV for charging them.
It looks like there are some people trying to help you with that so I'll leave you to them.
Probably not true.
I doubt city of Sacramento would add that requirement.
But direct burial wire would still require a lot of landscape disturbance (more than doing conduit since you'd be 24" down instead of the 18" down for PVC conduit).
So not any better than conduit I think (although might be a little cheaper in materials)Last edited by Narnian; 10-27-2016, 07:05 PM.Leave a comment:
I can run a power cable out there if we have a string of days with bad weather. But I think your second comment gave me a solution. The water needs to move 24/7 but it doesn't have to be full volume 24/7. I can set up a timer on 4 of the 5 low volume pumps so that they turn off in the evening and turn on in the morning. 1 deep cell battery would power a single pump without breaking a sweat. It should be able to handle a single pump for about 50 hours. Any reason this won't work?
20A charge controller (Amazon) $19.58 12V timer switch (Amazon) $8.99 240/410 GPH pump 4 pack (Amazon) $182.37 240 / 410 pump (Amazon) $49.00 100W Solar panel (Amazon) $117.99 Solar Panel Connectors pack (Amazon) $6.99 Wires (Home Depot) $20.00 2 battery terminal clamps (Autozone) $16.00 12V Deep Cell Battery (Sams club) $90.00 Total $510.92
What is the Ah rating of those Sams club?Leave a comment:
Electrician: $350
Trencher $120 /day (Home Depot)
Permit/s $50
Materials (conduit, elbows, enclosure, boxes for going in in and out the garage, 200' wire, outlets, circuit breaker, etc) : $300
That adds up roughly to $900. My materials might be a little high but generally every time I make an estimate it's too low.
I would look at doing a low-voltage, limited power set of wires from the house to the pond. A "landscape lighting" style system.
Wires for those are only required to be buried 6" deep per code. And that's shallow enough you can probably do that by hand and could maybe even do it by just slitting with the shovel and shove the wire down - minimizing landscape disturbance.
Given the power needed by the pump and the length of the run, you'd need to be careful about wire size, and would want to use the highest allowed "low" voltage to reduce power loss.
According to http://ecmweb.com/content/code-rules...ltage-lighting the max voltage allowed in wet locations is 15V.
Check e.g. https://www.altestore.com/howto/wire...-systems-a106/ to see what thickness wire you'd need.
