I have 2 x 100W portable panels, 1 x Group 31 AGM battery, and a Windy Nation P30L CC.
In the photo, where I have highlighted with arrows, these are the connect and disconnect points that can be set, right?
(but I am thinking, based on the arrow going to the "load", that the reconnect is ONLY for the load?)
Can you tell me if these two default settings are as they should be?
Second question - temperature probe - what is a good way to adhere the end to the battery? The hole in the connector is WAY too small to fit over the battery post.
The manual says to use "an adhesive to attach the sensor to any side of the battery to be monitored, below the electrolyte level as shown."
Thanks!
Thanks!
