I would like some assistance or confirmation that I am correctly calculating the draw on an appliance (CPAP) that I would like to take camping. I would like to find out if this is correct to determine if it is even feasible to worry about trying to do or not.
I think that I have it figured out and then I read some more and get myself confused.
So, here it is. From the certification sticker on the back of the unit, it shows that it uses 100-115V~ 1.5A (1.7A max). (It is an AC only unit, but suitable for use with an inverter 115v - 200W / 300W surge.)
So if I understand this correctly, using the maximum draw, 115VAC X 1.7Amps AC = 195.5W, then converting it over to DC, take the 195.5W / 12V = 16.29Amps DC. Is this correct? So this device would use 16.3 Ah for each hour of use, correct? Thats a lot of power.
I know that there will be an additional draw that needs to be added for the inefficiency of the inverter as well, but not as concerned about that just yet.
I have done a little testing with a watt meter and found that in real life the unit is drawing less than 50W AC with the heater and humidifier off (which they both always are), but wanted to go with the sticker values for the extreme case.
Thanks in advance for your help and advice.
