Hi,
New to the forum and also, most things electrical aren't really my streong suit so bear with please
Basically, we live in a caravan in the middle of a field. My set up consists of 1x 250w panel connected to this charge controller - http://www.amazon.co.uk/waterproof-c...rge+controller
That is hooked up to a numax 110Ah XV31MF, this is practically new. I bought it (new) about 3 months ago and I took care to trickle charge on mains for 48 hours before putting it into the caravan so should be fine.
Then I have an inverter similar to this one, except it is the 1000w/1500wpeak version - http://www.ebay.co.uk/itm/2000W-Peak...QAAOSwgkRVVMbZ
I can't find my exact inverter anymore, but this is the closest to it, the badge on the front is identical. The inverter is connected via crocodile clips onto the battery terminals.
The problem is this, my system runs fine with the LED lighting etc. When I try and plug my laptop in via the inverter, the indicator on the charge controller goes from green or flashing green to RED very quickly, within a few minutes.
I don't use it once it goes to red, however, the minute I turn the inverter off the CC indicator goes back to green?!?
This problem happened again last night so I used a multimeter on the battery this morning and it was reading 12.56v and slowly increasing (cloudy day down in the SW)... I think ten mins later it had gone to 12.59v. So the battery is definately being recharged via panel.
Am I right in thinking that all of this points to a 'dodgy' inverter?? Or is there something else I am missing/getting wrong.
Any help would be greatly appreciated (especially if in nice easy laymans terms
), I'll try and answer any further questions about setup as best I can.
Many thanks.
Many thanks.
