Directly using PV panel (without batteries/inverter)
  • gfry2267
    • Oct 2015
    • 6
    fun
    maybe my learning curve is slow- thats ok
    bought a sun king 250w inverter
    bought an ac disconnect box and 4awg wire
    its all connected and waiting for sun
    trying to cut my losses
    are ecoworthy panels ****?
    i can can only get 5+ amps in parallel/ 2 100 watt panels
    thanks for reading
    • LETitROLL
      • May 2014
      • 286
      thanks for reading
      Most 100W panels can put out approx. 5A max. each (check the Isc on specs), so in parallel you normally would expect 10A, however that max is only near solar noon with proper sun/panel angle, temp, etc. Are you using a charge controller? If so that will impact the total throughput greatly depending on the specific CC.
      • gfry2267
        • Oct 2015
        • 6
        i tested today and got around 6 amps at around 15 v - around 100w in parallel-2 100 watt panels- so you are correct. i must not be at optimal setup. no charge controller or batteries.
        i am running directly to plug and play 250w grid imeshbean tie inverter/ through an ac disconnect box. lots of wire, i expect loss. at max today kilawatt showed max 90+ watts / .22 kwh.
        Eco-Worthy offers off grid solar solutions which includes LiFePO4 lithium battery, solar panel and solar panel kits, mounting brackets and other accessories. We aim to provide high-quality off grid solar power solutions at an affordable price.
        Thanks for your response.
        Go Pack!!
        • LETitROLL
          • May 2014
          • 286
          Go Pack!!
          Was the 6A at 15V reading direct from the panel pigtail (everything else disconnected) or with system hooked up to the GTI?
          • gfry2267
            • Oct 2015
            • 6
            it was connected to the gti and then a kilawatt meter plugged into the ac wall socket. so maybe 6a 15v wasn't too bad given all the potential loss in wiring and I am sure I didn't have the panels optimally pointed. But they were in some good direct sun.Thanks for the reply. I will have to play some more. Maybe I will switch energy and finances to making a bigger solar can collector and use the panels for fans.
