[QUOTE=LETitROLL;178872]A good temperature correcting hydrometer only costs $9 on Amazon. (http://www.amazon.com/gp/product/B00...dp_o_pd_nS_ttl)
A year from now, that is probably the only piece of equipment he will still have that is useful. So, you tell me. After he buys a charger and charges his battery, how will he know if it is really charged without one?
small solar kit not working right, please help
[QUOTE=lkruper;178794]It is something everyone should have once they have a working system, we are not there yet, budget needs to go to production first, we do not know what budget is, just like we did not know what solar input was, only one person here asked that question before giving advice.Leave a comment:
Sadly, the cardboard boxes the panels came in, are likely more valuable than the panels.there 3 15w panels just the harbor freight ones
[QUOTE=LETitROLL;178791]will do, thanks for your advice very much appreciated.
You better get a battery charger on your batteries as soon as possible, and no need to go out and buy anything else right now (hydrometer) until you get more solar panels, if you are going to keep this setup. Those panels only put out 45 watts under perfect conditions for a few minutes a day and most inexpensive controllers will not pass that to your batteries without moderate losses, so you are using some energy and not putting hardly any back in. At least this one is simple to troubleshoot.Leave a comment:
[QUOTE=lkruper;178794]i still might try to get one of those meters, thanks again for all your helpLeave a comment:
ok great, thats kinda what i was thinking but again have no clue, my wife had bought all of this for me and was going the info that the harbor freight employee was telling her, but me nor her no anything about all this, so, i really appreciate your info this makes very clear sense now, i will look to downsize my inverter and or get more panels, as well as get a battery charger asap, thanks againSystem that is way out of balance and the panels are too small to support the load.
lets look
45 watts of panels
500watt charge controller
@150AH of batteries
2000 watt inverter
A basic rule to follow would be 1 watt of panels for every AH of battery for a 12v system for every 4 hours of insulation. You can see your about 1/3 that so you're not supplying them with enough amperage to properly charge.
You should also limit the inverter to a maximum of 2 watts for every AH of battery on a 12VDC system. That's 300W instead of 2000W. You're wasting most if not all the power you produce in running the oversize inverter.
You're load. It would help if you told us the wattage of the bulb and how many hours daily you are trying to run it. My guess would be a 60 watt bulb for 2 to 3 hours this time of year. That would only be 120 to 180wH a day. But the panel is most likely only producing @ 135wH this time of year. When you calculate in standard inefficiencies that only leaves about 75wH to 85wH to charge the batteries. We already know you're running an oversized inverter so you're inefficiencies are way higher than normal.
WWWLeave a comment:
[QUOTE=LETitROLL;178791]I will disagree that he should not spend a few dollars on a hydrometer at the same time that he gets a battery charger. How will he know if his batteries are really charged without measuring the specific gravity?
[QUOTE=davemx90;178781]You better get a battery charger on your batteries as soon as possible, and no need to go out and buy anything else right now (hydrometer) until you get more solar panels, if you are going to keep this setup. Those panels only put out 45 watts under perfect conditions for a few minutes a day and most inexpensive controllers will not pass that to your batteries without moderate losses, so you are using some energy and not putting hardly any back in. At least this one is simple to troubleshoot.Leave a comment:
lets look
45 watts of panels
@150AH of batteries
2000 watt inverter
WWWLeave a comment:
[QUOTE=LETitROLL;178740]How many watts are the panels?[/
there 3 15w panels just the harbor freight onesLeave a comment:
there autocraft deep cycle marine batteries, cca550, reserve capacity 140, marine cranking amp 685, thats all the info on them.What are the make and model of your batteries? If they are flooded lead acid batteries you must get a hydrometer. That is the only way to know if they are charged. Get one that has temperature correction. Once you see if the batteries are charged or not, you can start to troubleshoot.
One thing that happens when batteries are put into parallel is that a failure of one will affect the other. Also, there is a battery charger called an Optimate 6 which can fix and/or troubleshoot batteries. I do not have one, but a regular here on the forum highly recommends them.Leave a comment:
What are the make and model of your batteries? If they are flooded lead acid batteries you must get a hydrometer. That is the only way to know if they are charged. Get one that has temperature correction. Once you see if the batteries are charged or not, you can start to troubleshoot.it did work when i first wired it all up then after the firs day of running the light for a little while the alarm started beeping, the batteries are new, im pretty sure there lead acid, if thats what you mean, if not i dont think i have a hydro meter, but the charge controller was saying the batteries were putting out about 10.9 to 11 v i thinks.
i think i did initially, i remember a few people saying that on some vids, cuz it could short something out right.Leave a comment:
it did work when i first wired it all up then after the firs day of running the light for a little while the alarm started beeping, the batteries are new, im pretty sure there lead acid, if thats what you mean, if not i dont think i have a hydro meter, but the charge controller was saying the batteries were putting out about 10.9 to 11 v i thinks.Harbor Freight ... you made the first step in admitting you bought from them.... that is the hardest.... you can now recover
Has this setup ever worked at all? Also, are your 12v batteries flooded batteries and if so, do you have a hydrometer to check to see if they are charged? That is the only way to know for sure. If they are sealed batteries, you will need to check the voltage on them.Leave a comment:
