Solar Pi
  • Fenlig
    • Jun 2015
    Solar Pi
    Hey Guys,
    Thanks for reading I'm kinda new to the whole electrical stuff and solar power, so please be gentle.
    I've setup a 12v 80w solar panel in a temporary spot in-front of a large window in my apartment, I've connected it to a solar charge controller and 2x 12v 12Ah lead acid battery in parallel. I have also connected a small USB car cigarette adapter to the load and use that to power my raspberry pi(mini computer) 24/7.
    I wanted to expand the capibilities of the system to have an AC application to run some low power equipment like a wifi repeater so I bought a 300w AC transformer, just connecting it to the setup completely drains the system in a few hours.
    Can anyone see where I am going wrong and possibly offer a solution?
    Pictures: http://imgur.com/a/587c5
    Big thanks,
    Fenlig
  • Naptown
    • 6880
    You don't have nearly the battery capacity or panel wattage to run that for more than a short while.
    See the off grid stickie in my sig line
      You are 400 watts short on panels and 300 pounds short on battery.
        Plus the window is probably costing close to 50% in panel power....
          • 15207
          Originally posted by Fenlig
          Hey Guys,
          Big thanks,
          Fenlig
          You have run into the simple example of trying to run too big a load with a very small solar/battery system.
          As long as your "load" was only the USB car charger for your raspberry you were probably ok.
          But with that 80 watt panel behind the window and a 12volt 24Ah battery system you can only safely get about 60 watt hours out of it a day and will probably take 2 - 3 days to put it back.
