I was going to purchase an MC3 / MC4 crimper until...
  • ILFE
    • 236
    ... I found Mike's post in a thread on this site:
    Terminals should be crimped only. Proper crimping "cold welds" things together.
    Solder wicks up the wire and makes it stiff, creating a "fulcrum" that flexes and breaks the wire at the end of the solder, with any small motion.
    I used "Hydraulic Crimping Tool Kit 8 Ton Electric Wire Crimper " which is a metric size. I got mine off an eBay store - http://myworld.ebay.com/sarohs/&_trk...84.m1439.l2754 for about $100
    After following the link to the eBay seller Mike dealt with before, I looked up the item in question (which I believe to be the same one he purchased): Hydraulic Crimping Tool Kit 8 Ton Electric Wire Crimper
    Mike, did you buy terminals from this same seller? Or, did you purchase them elsewhere?
    I am thankful for this site and glad there are members here like you, who contribute as you do, making a "newbies" life much easier.
    Thanks,
    Paul
  • Naptown
    • 6880
    Thanks,
    that is over kill for what you want and really won't do the job properly. You need to look for an MC4 specific crimper. The crimp style is a bit different on these connectors. (also be prepared for a bit of sticker shock ours cost about $400 US but I have seen them for a little as 35 euro's
      Search for MC4 crimper tool on ebay - lots there and all price ranges. For home use a cheap one is probably OK but for commercial you should be looking at what Rich was pointing out.
      • ILFE
        • 236
        Thanks!
        Thanks, guys.
        Yeah, I just want to be able to build my own systems here. It (off grid power) will be necessary, due to the fact that the home is 5 kilometers from the nearest power lines. Considering this is Cambodia, and power here is anything but clean, constant, and reliable, that isn't a bad thing.
        Paul
