Hi,anybody have an idea if electrical varnish will work as encapsulant for cells?
electrical varnish for solar cell encapsulation
If it worked well in the long term, commercial panels would use it.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
pls. excuse my ignorance. maybe you could tell me more about the effects of this varnish.If it could keep my panels running for ten years,its ok. Maybe you have an idea around how long will cells sandwhiched between glass and plywood produce at least 50% of their power.Comment
2 years in a high humidity area would be excelent for home brew panels, in my opinion.
When they start to fail, I expect the end would come soon, rather than a year later.
The coating and the cells, must be the same themal expansion, or be flexible enough to not damage the cells. Varnish, I expect, would quickly flake and peel off. And it's not clear, it will reduce the power the cells can produce.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
