What type of connectors is everyone soldering onto their panels? I would like some easy disconnect connectors that will last in the weather.
Panel Connectors
I use neutral lugs. One mounted on top and the other on bottom of the panel. This allows me to keep the positive and negative wires seperated and can easily connect panels in series / parallel by simple screwing.
warning though if you use them. when you torque down the wires to much force will twist the lugs on the frame.Last edited by Sampson77; 05-15-2009, 04:54 PM. -
Thanks Sampson-
Do you have a link to an example of a nuetral lug. Also, can you damage your solar cells if you touch the positive and negative together?
MIkeComment
I just found nuetral lug on google so nevermind, I would still like to know if there ae any negative consequnces to touching the + and - together.Comment
you probably could if there was enough current flowing. But realistically all you would be doing is creating a short. On a small current no big deal. Large current its a big deal.Comment
http://www.amazon.com/Siemens-Neutra.../dp/B000NCTKZQ
Here is a link to one posted on amazon. I think they may be available at local hardware or auto stores.Comment
Neutral Lug Kit
Thank you very much. Now i know. To whom want to see it can click:
Thanks for the link to the connectors. I actually was looking at those at my local Lowes today. They are only $2 but I did pass on them. I was hoping to maybe find something waterproof. I was thinking later I could buy a shallow water-proof box & maybe mount the lugs inside.
I finished my 1st panel late yesterday, but it's been cloudy/rainy/icy all weekend. I want to check the voltage before I seal the plexi-glass.
Thanks again.[url="http://solarpaneltalk.com/album.php?u=2072"]First panel 40 volts, 140+ watts[/url]Comment
I went to homedepot and bought two grounding bars and put them in a box away from each other and use one for + and the other for - ,this keeps them apart from each other and you can add leads into the fuse boxes also.Comment
I prefer to use Anderson Connectors :http://www.andersonpower.com/ & http://store.solar-electric.com/anhicupoco.html
widely used by many industries, the connectors are rugged, and nearly idiot-proof.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
